Warning: Illegal string offset 'html' in /home/nissansi/public_html/forums/cache/skin_cache/cacheid_3/skin_topic.php on line 380
Warning: Cannot modify header information - headers already sent by (output started at /home/nissansi/public_html/forums/cache/skin_cache/cacheid_3/skin_topic.php:380) in /home/nissansi/public_html/forums/admin/sources/classes/output/formats/html/htmlOutput.php on line 110
Warning: Cannot modify header information - headers already sent by (output started at /home/nissansi/public_html/forums/cache/skin_cache/cacheid_3/skin_topic.php:380) in /home/nissansi/public_html/forums/admin/sources/classes/output/formats/html/htmlOutput.php on line 127
Warning: Cannot modify header information - headers already sent by (output started at /home/nissansi/public_html/forums/cache/skin_cache/cacheid_3/skin_topic.php:380) in /home/nissansi/public_html/forums/admin/sources/classes/output/formats/html/htmlOutput.php on line 136
Warning: Cannot modify header information - headers already sent by (output started at /home/nissansi/public_html/forums/cache/skin_cache/cacheid_3/skin_topic.php:380) in /home/nissansi/public_html/forums/admin/sources/classes/output/formats/html/htmlOutput.php on line 137
Warning: Cannot modify header information - headers already sent by (output started at /home/nissansi/public_html/forums/cache/skin_cache/cacheid_3/skin_topic.php:380) in /home/nissansi/public_html/forums/admin/sources/classes/output/formats/html/htmlOutput.php on line 141
FS: 97 180sx Type X $15,000 - Hardtuned.net
←  Cars for Sale
Hardtuned Classifieds
bluebanana's Photo bluebanana 28 Apr 2017
120 xxx km
109 xxx km on s15 dash
ENGINE:
- SR20DET 210kw 14.5 psi
- Tomei PonCams
- Garret GT-2860RS turbo
- Earls braided turbo lines (oil line not fitted)
- Walbro hi-flow fuel pump
- Z32 AFM
- Nismo 740CC Injectors
- Greddy FMIC
- Greddy intake pipe
- Stainless steel manifold
- Gktech dump+front pipe
- Nismo catback
- HKS super dragger muffler
- ProfecB Spec2 EBC
- Nistune Piggyback ECU
- GFB deceptor pro
- Morroso oversized sump
- HKS Oil filter relocation
- Powercoated rocker cover + modified breather (no T piece)
- Gktech airbox
- Gktech catch can
- Gktech eccentric throttle wheel
- Gktech rocker arm stopper
- Battery in boot with isolator
COOLING
- 52mm radiator
- Gktech fan
- Low temp thermostat
- Earls power steering cooler with braided lines
- HKS oil cooler
- Greddy swirl pot
- Yoshi factory water pump pulley
SUSPENSION:
- Whiteline rear adjustable swaybar
- Gktech front adjustable swaybar
- Cusco fully adjustable toe/camber/traction/control rods
- Hardrace rear knuckle bushes
- 5 stud rear hubs
- Gktech 5 stud conversion spacers in front
- Gktech solid steering shaft spacer
BRAKES:
- Slotted rotors all round
- Gktech abs delete
- Gktech braided brake lines
- Z32 front calipers
- S15 brake master cylinder
- Pmu B-spec pads rear
- QFM front pads
- Gktech master cylinder stopper
- S14 wheels
- Gktech wheel nuts
DRIVETRAIN:
- Toda lightweight flywheel
- Exedy 3 puk clutch
- Nismo slave cylinder
- Nismo 1 way 4.3 diff
- New front bearings, seals and gaskets in gearbox
- Gktech shifter springs + bushings + pivot ball
- Gktech braided clutch line
- Cusco engine mounts
- Nismo gearbox mount
- Gktech solid diff bushes
- Short shifter
BRACING:
- Cusco 3 point rear strut brace
- Custom made 4pt boot brace
- Custom c pillar brace
- Ultra racing fender brace
- Nismo power brace
- Tomei 3 point strut brace
- Spot welded complete interior + removed sound deadening
- Cusco side intrusion brace
INTERIOR:
- Mongoose alarm system with 3-point immobiliser
- S15 dash conversion (fully functional)
- S15 floor mats
- S15 scuff plates
- S15 rear view mirror
- S15 sunvisors
- S15 dome light
- S15 passenger seat
- Nismo leather gearknob
- Pivot headlight controller
- Apexi ecv
- Black headlining
- Bride Gias Low Max replica driver seat
- Genuine Bride rail
- Nismo clutch pedal bracket
- Fire extinguisher
- Kill switch
- Replica Defi gauges in air vent (oil pressure gauge doesnt want to work atm)
- Autometer Boost gauge mounted on a piller
BODY:
- 2up carbon roof spoiler
- Raybrig headlights
- Kmak fbreglass front + rear lip
- Gktech aero mirrors
- RPS13 carbon fibre OEM centre garnish
- OEM nissan rain deflectors
- Shaved rear wiper + 3rd brake light
- New oem door seals
- ONE 80X plates included with sale
No A/C. No ABS - not supplied
No interior in boot, will be supplied.
Can also supply (for the right price) :
- S15 rear subframe with Gktech solid offset bushes installed, S15 rear lca's and Gktech weld in braces (not welded yet) aswell as a 2 bolt diff hat cleaned up and ready to go.
- S15 driver seat
- Ultra racing 4 point front lower brace
Has 3 folders full of reciepts starting from first Australian owner..
Bad points - Boot paint is starting to crack (had too many spoilers in its life) and a bit of a dent left rear quarter quarter
No joy rides, no stupid offers
  • Attached Image
  • Attached Image
  • Attached Image
  • Attached Image
  • Attached Image
  • Attached Image
Quote
S15 sxytime's Photo S15 sxytime 28 Apr 2017
Location, price, receipts for work done / parts?
Quote
Sorry.
Price: $15 000
Have over 15k in receipts from first australian owner. Majority of work done myself as I'm a mechanic.
Quote
Typex's Photo Typex 24 Jul 2017
pmd
Quote
