MCA Gold Coilovers for S15 - 30,xxxx kms - Hardtuned.net
Targa Silvla S15 200SX Race Hillclimb Circuit Drift Time Attack Competition
  • You cannot reply to this topic
No replies to this topic
#1 Xxx_Ruff_Ryda_xxX
  • Car:Flutterz y0!
Posted 02 April 2017 - 12:28 PM
Selling my beloved S15 MCA Gold series coiloverscheaper than the MCA Red series.
The Golds are all custom hand made and designed for all road setups.
Springs are King Springs, 400 lbs (7.1 kg) front and 325 lbs (5.8 kg) rear spring rate, linear springs.
Only used for 30,xxx kms, daily for a year and then a weekend only car with the odd hill run.
Not required yet but these can either be rebuilt at any motorcycle shop or at the MCA workshop in QLD.
Car was defected so had to change back to stock and decided to save for an engine build.
Has many adjustments for travel, castor (over 9 degrees each side), front camber, front toe, rebound and dampening.
They can get very low but depends if you want to look cool or care about roll centre correction for handling.
You can call Josh or Murray Coote for support on these from the MCA suspension website:
https://mcasuspension.com/
Asking $2500 or near offer.
Local pickup welcome from West of Adelaide or southern suburbs area.
WILL POST FOR $50 ANYWHERE IN AU.
Any questions, just ask.
Cheers.
  • Attached Image: mca.jpg
  • Attached Image: mca4.jpg
  • Attached Image: mca5.jpg
  • Attached Image: mca6.jpg
  • Attached Image: mca7.jpg
  • Attached Image: mca8.jpg
Edited by Xxx_Ruff_Ryda_xxX, 02 April 2017 - 12:42 PM.
