enkei rpf1. s14 r33 driveline bits. haltech etc - Hardtuned.net
enkei rpf1. s14 r33 driveline bits. haltech etc Australia - Vic
1 reply to this topic
#1 blingcommander
  • Car:Scooty-Puff Jr.
Posted 02 May 2017 - 07:53 PM
Items for sale. All located in Drouin, vic and can be posted at you cost. Pickup from pakenham can be organised as well.
Enkei rpf1. Front 17x9 +22 with near new 215/45 kuhmo ku31s. Rear 18x9.5 +38 with worn 235/40. Also included is 15mm gktech bolt on spacers for the front. Wheels are in average condition. One front is pretty rashed. Both rears are rashed on the inside.
$1100
Haltech ps1000, air tem sensor and patch loom to suit s1 s14 sr20det
$1200 delivered in aus
Bc br coilovers to suit r33. Did 1 track day perfect condition
$700
S14 sr20det gearbox. Good condition. Not needed because shifter is in the wrong spot for what i needed.
Borg warner 4.1 diff gears
$300 delivered in aus
Borg warner 31 spline spool. Msf racing components $200 delivered in aus
S14/r33 rear subframe. Braced at lca mounts and toe arm mounts. Has solid subframe mounts fitted. R33 auto 4.3 lsd diff recently shimmed and r33 driveshafts. R33 gtr swaybar with new link bushes. Gktech toe, traction and camber arms. Knuckles have spherical joints at the toe and traction arms and nolothane at the camber arm. Comes with handbrake cables but no hubs. Also included is gktech caster arms for s14/r33.
$700
Will have pics in the next few days. Photobucket is being a cunt
#2 Mort
  • Car:74 LH SL/R Torana
Posted 18 August 2017 - 04:52 PM
Do you still have the gearbox for sale, if so how much and if possible how much for freight to Moranbah, Queensland, 4744.
Thanks.
