TTuned Horse Power Heroes! - Hardtuned.net
30 replies to this topic
#1 blind_injustice
  • Car:GM Test pilot
Posted 27 October 2010 - 09:55 AM
TTuned Horsepower Heroes Leaderboard!
Rules: Must have Dyno Readout sheet posted.
Must have Spec posted as this.
Engine:
Turbo:
Mods:
Nos: Y/N
Have fun guys!
#2 -Kempo-
  • Car:JZZ30 Soarer
Posted 27 October 2010 - 04:22 PM
Dean. | 1jzgte - Jzz30 | ct12a's TT | 160rwkws | Standard
Can't find dyno sheet atm, will look for it.
#3 Fro-Daddy
  • Car:Chaser JZX100
Posted 28 October 2010 - 07:06 AM
Ryan | 1JZ-GTE with VVTi | GT3076R core in standard CT16b housings | 325rwhp | 16psi
#4 blingcommander
  • Car:Scooty-Puff Jr.
Posted 27 November 2010 - 08:58 PM
Komen / 1jz vvti / hypergear 30/76 highflow / 375rwhp / around 20psi
  • Attached Image: dyno sheet.jpg
#5 Devils Cef
  • Car:2JZ S15
Posted 27 November 2010 - 11:08 PM
Matt / 2jz-gte / Innovative T76 / 401.6 rwhp / 15psi
#6 blingcommander
Posted 27 November 2010 - 11:17 PM
well i was number 1 for all of about 2 hours :lol:
fkn crank that shit matt!!
#7 Devils Cef
  • Car:2JZ S15
Posted 27 November 2010 - 11:41 PM
Haha I saw it earlier and thought I'd let be No.1, just for a bit lol. Anyways it's gonna make way more once I put in my 1000cc, run a toluene mix and crank 1.5 bar into it...
#8 blind_injustice
  • Car:GM Test pilot
Posted 28 November 2010 - 11:15 AM
good work boys! glad to see some numbers being put up!
#9 blownminiturbo
  • Car:jzz30 soarer
Posted 09 December 2010 - 08:05 PM
Aaron / 1jz / t70 / 231.1rwkw running 12psi have dyno sheet somewhere but that was long time ago.
been through a few turbo setups since then... aiming for the 500rwhp with 2j, 35r, 264 cams, emanage, 650cc sards etc etc... :)
#10 rotaheadrx7
  • Car:R33/D40 navara
Posted 18 December 2010 - 03:28 PM
My soarer made 305rwkw on 17psi with the previous owner, MR 1JZ. SFA Timing, Safe tune and 6800rpm limiter to keep it alive.
We're Adding 1100cc injectors and a dual feed rail, HKS 272/9.3 cams and another 044 and tuning for 450rwkw/600rwhp on 98ron pump fuel.
| Ben | 2JZGTE | Trust T78-33D 17cm | 304.7rwkw/408.6RWHP | 17PSI
No dyno sheet by here is a video of the dyno run and the graph displayed.
#11 -Kempo-
  • Car:JZZ30 Soarer
Posted 28 April 2011 - 02:35 PM
Update for my soarer. 177kws on 11psi, aftermarket exhaust. still have the twins.
Attached Image: dyno 177kws.jpg
#12 blind_injustice
  • Car:GM Test pilot
Posted 28 April 2011 - 03:00 PM
Will update shortly. well.. after work.
#13 Jason12
  • Car:Cressida
Posted 16 May 2011 - 08:35 PM
204.6kw - 1jz cressida. 3in exhaust (stock cat and dumps), cooler, 040, emanage, 17psi.
Punching cat and taking out a muffler and going for 220+
#14 PZE57
Posted 22 June 2011 - 07:40 AM
Nghia-jzx100 1jz-gte vvti/hks 3037/sard 550cc/fuel pump/apexi pfc/16psi-385hp
#15 blingcommander
Posted 22 June 2011 - 07:59 AM
^^ i would be running 20psi, then you will see it come alive.
#16 natett
  • Car:Mkiv tt supra
Posted 22 June 2011 - 11:29 AM
supra. 2jzgte stock motor. fuel clutch exhaust gt42r single turbo bla bla bla
#17 PZE57
Posted 22 June 2011 - 03:17 PM
It won't hold 18psi so there's no point pushing it any further. I've got a new turbo set up on order! Gtx35r/ 6boost/22psi etc. Check members rides :)
#18 blingcommander
Posted 22 June 2011 - 03:49 PM
ahh, that sucks. new setup sounds brutal! i'm waiting on a borgwarner EFR7670 myself :D
#19 blind_injustice
  • Car:GM Test pilot
Posted 20 July 2011 - 04:17 PM
Will be updating soon. Sorry fella's!
#20 EnFlaMEd
Posted 17 August 2011 - 07:02 PM
André / 1jz / stock twin ct12a / 312rwhp / 15psi
#21 PZE57
Posted 17 August 2011 - 07:33 PM
Sorry, it was 385hp on 16psi
Thanks,
Nghia
#22 FST 02J
  • Car:Toyota Supra S2
Posted 22 October 2011 - 03:29 PM
2jzgte twin high flow a80 286.8 rwkw 18psi 384.61rwhp 836nm
will be more after a new tune as its running rich on boost
Edited by FST 02J, 22 October 2011 - 03:30 PM.
#23 FST 02J
Posted 01 November 2011 - 08:32 PM
thinking of installing my twin plate and putting it back on the rolers to bet more power or just wind the boost up to where its tuned for :D
#24 adavis59
  • Car:Jzx90 Mark II
Posted 10 January 2012 - 08:29 AM
THats a awesome outcome!! my steel wheel ct12's are good for 20psi or something, so hoping for 250rwkw
#25 adavis59
  • Car:Jzx90 Mark II
Posted 10 January 2012 - 08:35 AM
JZX90 -
Standard exhaust, standard cooler, standard intake, standard boost... standard everything!
Attached Image: 72719_444541536049_583686049_5893411_7428199_n.jpg
3" exhaust, de cat, 13psi of boost using ebc. Still standard cooler & intake
Attached Image: 286530_10150245666056050_583686049_7953645_89513_o.jpg
Current set up -
twin steel wheel ct12s, twin dump pipes, 3" front pipe, front mount, walbro, hard intake with pod. Turbos good for 20psi+.
DYNO SHEET STILL TO COME!!
Edited by adavis59, 10 January 2012 - 08:37 AM.
#26 blind_injustice
  • Car:GM Test pilot
Posted 15 February 2013 - 12:25 PM
Been over a year since a post in here!
Any more high HP Toyota's floating around?!
#27 pman
    Pooh Bear; Wreckin' porcelain since the 90's.
  • Silver Member
  • Classifieds Items
  • PipPipPipPip
  • 1,182 posts
  • Car:RayGay's mum
Posted 15 February 2013 - 02:51 PM
Dean Newcombe and Daniel Prior should post up their figures. Both well over 300KW
#28 RxDrift
  • Car:GZ20 Soarer
Posted 02 April 2013 - 07:26 PM
Here you go pman! Didn't realise this was here...
I can't seem to find the actual dyno sheet but I'll put it up when I do. This is a comparison chart I made from the data on the sheets.
Engine: 1.5JZ (2JZ-GE bottom end)
Turbo: Garrett GT3082R 0.82 exhaust housing - 19psi
Mods: Standard head and block, china exhaust manifold, china bar/plate front mount, 3" exhaust, 540cc injectors, Microtech LTX12, Bosch coils, MSD leads, OS Giken twin plate, upgraded R154
302kw/405hp - 938NM torque
#29 greens14
Posted 02 April 2013 - 07:36 PM
Std internal SR20det, TD06 20g, cams, 1000cc inj, usual bolt ons.
260rwkw 18psi
Edited by greens14, 02 April 2013 - 07:37 PM.
#30 greens14
Posted 02 April 2013 - 07:38 PM
Waits for PJ to come and destroy everyone!!!
