Toyota Chaser - What power are you making? With what mods? - Hardtuned.net
34 replies to this topic
#1 Jap.SpeC
  • Car:180sx
Posted 26 June 2011 - 11:01 PM
Looking into getting a chaser, Just trying to gather some info on some of the first mods I should be making,
Obviously the usual, ECU, Injectors, Cooler, Exhaust, Fuel pump are the first mods on the list, But I wont be able to do them all at once..
Soo I thought I ask the question,
What power are you getting out of your Chaser..? And with what mods?
At the moment, Id be happy with 200 - 220rwkw what needs to be done to achieve this? Would I be able to achieve this with just an ECU upgrade?
Cheers guys, any info is much appreciated :)
#2 blingcommander
  • Car:Scooty-Puff Jr.
Posted 26 June 2011 - 11:18 PM
power fc, 1 bar boost, full exhaust, front mount cooler. done and done
i have a vvti 1j in my s14 and my old setup consisted of:
hypergear high flow turbo
40mm external gate on stock manifold
high flow injectors (700cc)
exhaust and cooler
autronic SM4 computer
280rwkw on 18psi
#3 sharkey
  • Car:rb25 cefiro
Posted 27 June 2011 - 01:14 AM
why a power fc blingy?
why not just a re-map?
without a pfc, would be cheap as f**k to get 200kw!
#4 wanted
  • Car:Jzx100
Posted 27 June 2011 - 01:22 AM
Dont think any one does a remap in aus for chasers? In mine I have power fc, 2835, Exaust, cooler, fuel pump made 250rwkw on 14psi
#5 blingcommander
Posted 27 June 2011 - 07:53 AM
exactly. who does a re-map for them??
#6 -**wHiStLe**-
  • Car:S15, R32, R33
Posted 27 June 2011 - 08:04 AM
Might throw little question related myself in here.
Are they much easier and more reliable to get a responsive 300 out of over an SR?
#7 X Kyle X
  • Car:HCR 32
Posted 27 June 2011 - 08:26 AM
Heaps reliable. Heaps more torque.
#8 -**wHiStLe**-
  • Car:S15, R32, R33
Posted 27 June 2011 - 09:15 AM
I'm tossing up whether to drop back to an S14 and build to around 280-300 or go chaser with the same.
#9 blingcommander
Posted 27 June 2011 - 09:19 AM
don't have to worry about building the engine, beefier gearbox. will cost the same for the bolt ons
#10 Jap.SpeC
  • Car:180sx
Posted 27 June 2011 - 10:06 AM
Just wanting to get the chaser n maybe get a tune for now..
How much power you think i could make with just a computer? ... Standard injectors,fuel pump, cooler and exhaust?
#11 Jason12
  • Car:Cressida
Posted 27 June 2011 - 11:17 AM
Ive got the non vvti 1j in my cressida and made 204.6kw with the std cat... Got exhaust with std dumps, cooler, 040 ,emanage blue running 17psi with a boost tee. think itd be a similar story with the single turbo 1js?
#12 Tats
  • Car:JZX100
Posted 27 June 2011 - 11:56 AM
Nobody does it in Aus, not sure if it's possible at all. You'll easily get up to 200rwkw with just intake and exhaust mods and 14psi, a power FC or emanage ultimate tuned will get you the sort of power you're after.
I've got 271rwkw with the basics plus GCG highflow, 525cc injectors, EMU and 20psi (turbo is already out of puff at this level)
#13 Fro-Daddy
  • Car:Chaser JZX100
Posted 27 June 2011 - 06:45 PM
I maxed out my completely standard fuel system at 243kW with a highflow turbo and a powerfc.
Mates car has the standard turbo with an emanage and has 233kW, 20psi midrange tapering to about 14psi up top.
Both of our cars have a profec b, 3.5" dump with 3" for the rest, fmic and intakes.
#14 Cellsplicer
  • Car:'91 Nissan Silvia Q's
Posted 27 June 2011 - 07:04 PM
Many Toyota ECUs including the 1JZ's cannot be remapped. Look at getting Power FC, Greddy E-Manage, HKS F-Con etc.
#15 blingcommander
Posted 27 June 2011 - 07:52 PM
was a rhetorical question... but it looks like high 200s are the limit of the manifold and exhaust housing no matter what high flow you go
#16 EnFlaMEd
Posted 02 July 2011 - 11:16 AM
Stock non vvti 1jz in my z20. Twin intake set up, trust front mount, Kakimoto Y-pipe back exhaust with high flow cat (stock dump), blitz access ROM, eboost2@15psi. I'm making 232rwkw and its still quite fat on the fuel side.
#17 PhattJZX
  • Car:JZX100 TRD Spec Yo!
Posted 11 August 2011 - 11:19 AM
I managed 202rwkw with only Turbo-back exhaust & Air pod, running around 10psi so that power level is easily achievable with very little mods.
#18 catbig
  • Car:JZX110
Posted 19 August 2011 - 11:29 PM
FMIC+ muffler 181kw on wheel
#19 buzzin
  • Car:Hilux, jzx90
Posted 16 October 2011 - 10:21 PM
1JZ non vvti in JZX90
253kw at 13 pounds
china spec T70
Ext gate
Helps manifold
2JZ injectors
600hp pump
straight through 3" exhaust
FMIC
#20 BQ.05.TD
  • Car:pulsar
Posted 21 December 2011 - 08:45 PM
Full zorst, fmic, gcg highflow and safc did 245 kw in a auto on stock ecu,fuel pump, injectors. Put power fc in and did f**k all. Manifold and rear housing won't flow any more
#21 blingcommander
Posted 22 December 2011 - 06:43 AM
errr. they have run out of puff dude, as well as the standard AFM if you still have that
#22 Red_Gem
  • Car:gtr
Posted 22 December 2011 - 09:26 AM
Didn't jrs31 make 300rwkw with STD afm?
#23 blingcommander
Posted 22 December 2011 - 10:14 AM
no idea, mate had to go a Z32 afm in his making 300
#24 Red_Gem
  • Car:gtr
Posted 22 December 2011 - 10:49 AM
Well my mate owns it now there was a build thread for it. I think it was "kintama jzx100" or something. Jrs31 or jrsA31 had it anyway it made just over 300rwkw with STD airflow meter.
#25 blingcommander
Posted 22 December 2011 - 01:15 PM
Fair enought, but by all the info on jzx100.com the afm tops out when the injectors do
#26 BQ.05.TD
  • Car:pulsar
Posted 22 December 2011 - 06:13 PM
Yer injectors are maxed out that's for sure. Trying to find the right size ID1000 that will fit so I can go E85
You can get 300 out of the stock AFM. Most keep it so you retain the air temp sensor
#27 Fro-Daddy
  • Car:Chaser JZX100
Posted 24 December 2011 - 10:57 AM
I know a guy that made 300kW at the wheels with the standard AFM as well, my injectors were maxed at 240kW though according to the PFC hand controller.
#28 darcey
  • Car:1997 JZX100 Chaser
Posted 20 January 2012 - 10:33 AM
1997 JZX100 - 170rwkw @ 10psi running a Power FC and HKS Legal exhaust
#29 Red_Gem
  • Car:gtr
Posted 20 January 2012 - 12:22 PM
2 friends of mine both tuned this week.
One is gtx3076, fc, standard AFM, injectors etc. Made 255rwkw.
The other with blingcommanders old turbo setup mate a very safe 262rwkw.
Edited by Red_Gem, 20 January 2012 - 12:22 PM.
#30 blingcommander
Posted 20 January 2012 - 01:34 PM
what boost are they both running?
hypergear POWAH :lol:
